17 years agoEPCS load failed
I came across the following problems when I used the Flash Programmer to download project to EPCS16 device. # !/bin/sh# # This file was automatically generated by the Nios II IDE Flash Programme...
14 years ago@sashawhosaid hey thanks,... thats exactly what i tried yesterday and it worked, but fitter failed repeatedly for multiple pins connected the EPCS outputs...
then had to do the following to compile it rite and the whole thing worked fine.. thanks to all who gave ur valuable help. 1. Make all dual purpose pins as User I/Os in Device settings. 2. Assignments > Device > Device and Pin Option > Configuration > Disable the "Enable input tri-state on active configuration pins in user mode" thanks once again !! :)
