11 years agoepcs does not configure cyclone V
Hello, my ecps on my board does not configure my fpga. I create a jic file and programm the epcs.This works ok. But my programm does not boot. With the nios2flash programmer i can convert sof2...
11 years agoVCCBAT range is 1.2V to 3.0V. So, 1.8V is fine (although not exactly in line with a note in the datasheet). It states:
--- Quote Start --- If you do not use the design security feature in Cyclone V devices, connect VCCBAT to a 1.5-V, 2.5-V, or 3.0-V power supply. Cyclone V power-on reset (POR) circuitry monitors VCCBAT. Cyclone V devices do not exit POR if VCCBAT is not powered up. --- Quote End --- Cheers, Alex
