11 years agoepcs does not configure cyclone V
Hello, my ecps on my board does not configure my fpga. I create a jic file and programm the epcs.This works ok. But my programm does not boot. With the nios2flash programmer i can convert sof2...
11 years agonyusof,
Changing those settings only affects the resulting configuration bitstream (.sof). So, any changes made there will only take effect once the configuration process starts - which, in AS mode, depends on nCE & DCLK. They, in turn, are dependent on the MSEL settings and the POR and little else. So, if you have no activity on nCE or DCLK you need to look at your board and not your Quartus settings. Cheers, Alex
