11 years agoepcs does not configure cyclone V
Hello, my ecps on my board does not configure my fpga. I create a jic file and programm the epcs.This works ok. But my programm does not boot. With the nios2flash programmer i can convert sof2...
11 years agoHello nyusof,
thanks for your quick answer. 1) yes i have set the configuration scheme to Active serial 2)i did also disable the EPCS ID but it still not the same. It is not a problem of silicon ID.The silicon ID has been recognized. I have controlled my design again and check the signals with an oscilloscop. +After programming the EPCS the nstatus line and the conf_done line still be low. +After powerup the EPCS chip select NCS remain high and the clock SCL low. thanks.
