17 years agoEPC16 does not configure EP2C35 at high temperature
Folks, I have been debugging this issue where the EPC16 device I use does not configure the EP2C35 (Cyclone II) device - at slightly high temperature. I can make it configure by cooling down bo...
17 years ago --- Quote Start --- it appears that there are some serious signal integrity issues on the board --- Quote End --- You're right, if the waveforms would be real. However, you easily get apparent overshoot by simply using a normal passive probe with standard ground lead.
