17 years agoEPC16 does not configure EP2C35 at high temperature
Folks, I have been debugging this issue where the EPC16 device I use does not configure the EP2C35 (Cyclone II) device - at slightly high temperature. I can make it configure by cooling down bo...
17 years ago --- Quote Start --- wouldn't you expect the FPGA to take over and start toggling the DCLK --- Quote End --- In PS mode, DCLK is controlled by the configuration device. But it's apparently never starting configuration, although all prerequisites are met according to the waveform. Another question: What happens, if you start a configuration manually through EPC16 JTAG interface?
