17 years agoEPC16 does not configure EP2C35 at high temperature
Folks, I have been debugging this issue where the EPC16 device I use does not configure the EP2C35 (Cyclone II) device - at slightly high temperature. I can make it configure by cooling down bo...
17 years ago --- Quote Start --- According to the waveforms, the EPC16 is simply not starting configuration after nSTATUS is deasserted. So I guess, the problem is related to this device rather than the FPGA. The reason for configuration failure can't be explained from the shown waveforms, I think. But it may be probably caused by other EPS16 signals, e. g. an incorrect terminated TCK. --- Quote End --- After the nSTATUS is de-asserted, wouldn't you expect the FPGA to take over and start toggling the DCLK. Once it receives the first frame of data, it will pulldown the INIT_DONE signal. Good thought about the TCK - I will check.
