14 years agoEP4CE6 Cyclone IVE FPGA regulator question
From the datasheet on the EP4CE6 under Power Supply Guidelines, it looks like it requires a switching regulator to produce the +1.2V? Can I use a linear regulator to do it, or why is it not recommen...
14 years ago --- Quote Start --- Does this mean, your power curves are simulation results rather than real measurements? P.S.: I presume the design is clocked by 50 MHz? --- Quote End --- The measurements are from the DE0-nano at 50MHz. The comment regarding the linear regulator shutdown could be a little clearer - it was meant to imply "If the DE0-nano 1.2V core was implemented using a single regulator ... ", however, since Terasic used a cascade of two linear regulators, the power was distributed between the two, and the regulators did not shut off (though the die temperatures would have gone up by 80C each - so I didn't run the test for long). The main point of the post is that switch-mode power supplies are significantly more efficient than linear regulators. Cheers, Dave
