lipingx
3 years agoEP4CE15U14A7N DDR2 interface
Use bank 2, 3, 4 for ddr2: micron MT47H128M16RT-25E:C TR question: 1) only 1 DQS pin marked in pin list, how to handle LDQS and UDOS? 2) The DDR2 DQS pin is differential, but FPGA is single end, h...
- 3 years ago
just read the device manual and pin list thoroughly.
Post #1 is quoting the DQS for x16/x18 column, however as clearly written in the device manual and stated in post #2, DDR2 RAM has to use x8/x9 DQS configuration. There are more DQS pins available for x8/x9, e.g. M7 and T7 in bottom banks B3/B4.
lipingx
3 years agoBut in below document, it tells current device can support 16 bit DDR at top or bottom.
It doesn't need both. but in your pin list, the only 1 DQS pin assigned.
So your documents doesn't match, please check why.
