14 years agoEP330PC-15 information needed
Ok, trying to repair an old ISA board that has an EP330PC-15 on it. I'd appreciate any information about this device.Yes, kinda old( 20 years) but this is alegacy device that must be maintained. A...
14 years agoThe closest datasheet I could find was for the EP320. (Same family, but different device).
I Don't work for Altera however. I'm sure they have it in an old databook somewhere. Attached is a PDF for the EP320 with a 20 pin pinout. I would assume the EP330 has a similar pinout, but I could be wrong. However since they are all just Clocks/Input or IO, the actual functionality you would still have to reverse engineer. Pete
