19 years ago"end of initialization" reset
Hi everybody, Are there internal power-up reset or "end of initialization" reset signals that can be read to check for start-up reset condition in cyclone FPGA's? Whitebird
19 years ago --- Quote Start --- The problem with INIT_DONE is that I don't know id it can be read internally --- Quote End --- Why do you need a signal to know internal to an FPGA that that same FPGA has completed initialization? When internal logic starts operating (as it has to do in order to look at an internal status signal for end of initialization), you know initialization has ended. There is no guarantee that every register in the device will exit the power-up reset condition at the same clock cycle. If you are wanting to create an internal reset signal that will make sure everything starts up on the same clock cycle (a good design practice), you can use my suggestion of a register clocking in a high as soon as possible. That register output can be the starting point for internal reset signals synchronized to the various clock domains. --- Quote Start --- OK, but it [every register being cleared at power up] seems not to be the case for state machines. I have a state machine like that (VHDL): type state_machine is(P1,P2,P3); signal state,statef:state_machine; But after end of initialization the first state is P2 and not P1! I want it to be P1. Don't know why it goes to P1. The state will be P1 only by the help of an external reset pin. --- Quote End --- If any of your states is encoded with all state bits low, that will be the state at power-up reset unless you override it with a reset signal to force a different initial state. If you want P1 to be the reset state at power up without asserting the reset signal and also to be the reset state when the reset signal is asserted later, then the P1 state code must have all bits low. This can be confusing if synthesis inserts inversions to make an internal register appear to power up high. I think that for all devices all internal registers power up low; any apparent high is accomplished with inverters. Some devices let you force registers to power up high, but I think that makes only I/O cell registers power up high (because there is no inverter available in the I/O cell to make an actually low register act like a high register).
