Encryption of FPGA design
I'm using the following devices:
5AGXFB1H4F35I3G
5SGXEA3H2F35I2L
5SGXEB6R2F40I2LN
Is it possible to encrypt the firmware running on those devices ?
The goal is to prevent someone to do a "reverse engineering" of the VHDL code.
Thank you,
Zvika
Does the above reply help? I believe you are looking for a way to encrypt your VHDL module, not your hardware right?
For Quartus Prime Pro you can use IEEE 1735 to encrypt and decrypt your RTL code.
For Quartus Prime Standard we offer Ampcrypt/Amplic tool to encrypt your RTL code. However you would need to contact your local sales representative to obtain this tool.
Nurina
- Nurina
Hi, do you have any updates?
Nurina
- ZVere
Thank you very much for your reply.
We will soon try it.
Zvi Vered
- Nurina
Hi Zvi,
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
- Nurina
Nurina
- ak6dn
Have you read this app note:
https://www.intel.com/content/dam/support/us/en/programmable/kdb/pdfs/literature/an/an556.pdf
- Nurina
May I know which Quartus version you're using?
Nurina
- ZVere
The Quartus version is not a problem.
If required, we can upgrade to any version that supports this feature.
Thank you,
Zvi Vered
