Avina
2 years agoEncrypting configuration .sof file using Command line interface
Hi, I need to convert .sof file into .jic & .ekp files using the command line in order to use it in an automatic post flow script. I was trying to run the following command: quartus_cpf -c design...
FakhrulA_altera
2 years agoHi Avina,
Could you try to check the compression command found in table 4 on page 14, here: https://cdrdv2.intel.com/v1/dl/getContent/733068?fileName=ug-683432-733068.pdf
Btw, have you tried using Quartus GUI? Is it working?
Also, can you try to use the latest Quartus version?
Fakhrul
