Avina
2 years agoEncrypting configuration .sof file using Command line interface
Hi, I need to convert .sof file into .jic & .ekp files using the command line in order to use it in an automatic post flow script. I was trying to run the following command: quartus_cpf -c design...
FakhrulA_altera
2 years agoHi Avina,
You might want to take a look at a related post:
quartus_cpf - converting sof file to encrypted pof (with ekp included) for Max 10 FPGA
Fakhrul
Avina
2 years agoHi Fakhrul,
thanks for your reply,
your answer doesn't help me to much.. i need to compress the .sof file and create a .jic encrypted file
i need the complete syntax (include the compression option enable) to run in the command line.
the following command ended with the following error:
quartus_cpf -c design_file.sof design_file.jic -d EPCS128 -s EP4SGX530 -k key_file.key key1:key2
"size of file(s) in EPCS128 exceeds memory capacity"
hope you can answer me quickly
Avi
