JackLusenhop
2 years agoEnabling HPS-FPGA bridges on Agilex 7
Hello, I have been trying to run the HPS system on the Agilex™ 7 FPGA F-Series Development Kit (P-Tile and E-Tile), DK-DEV-AGF014EA and have been following two tutorials: https://www.rocketboards...
JackLusenhop
2 years agoHi,
That is good to know I can ignore those. Do you have any idea what could be causing the error:
"Failed to enable the HPS bridges, check bridges availability. Status 4."
during the u-boot process? Could it be an issue with the device tree? Do I need to specify the bridges there? I found the hps_bridges mentioned in the device tree inside the socfpga-linux kernel, but not inside the u-boot.
Jack
