rshal2
7 years agoEnabling bridges - When and How ?
I find the following warning: " Note: Before re-programming the FPGA fabric, make sure that the FPGA2HPS bridges (f2sdram, axi) are disabled, and that there is no software on HPS that may access th...
rshal2
7 years agoHello,
We don't have bootloader, just running preloader and baremetal.
In such case how does fpga2sdram get enabled ?
Thank you
- EBERLAZARE_I_Intel7 years ago
Okay, you can enable them from preloader as it checks the status of the FPGA and automatically enables bridges configured in Platform Designer (QSYS) and the BSP if the FPGA is configured.
Remember the "bridge_enable_handoff" command? This can be run from the U-boot command prompt to enable bridges. This command puts the HPS and SDRAM into a safe state before enabling all bridges after appropriate checks.
Regards.
