Enabling bridges - When and How ?
Hi ranran,
As mentioned "Before re-programming", thus this is to make sure all previous settings and configurations are disabled and shut down. So that if you decide to reprogrammed your design, it can configure accordingly without having previous settings and configuration affecting the design that you decide to re-programmed.
Regards.
I think the following page partly answers my question:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/embedded/2016/how-and-when-can-i-enable-the-fpga2sdram-bridge-on-cyclone-v-soc.html
If I understand correctly:
- The warning in my original question is solved by just stopping HPS application (Right?)
- enabling all bridge is done in preloader
- fpga2sdram seems like a special bridge, which requires to be enabled only in certain state.
In our case fpga is configured independently from HPS, so we can't use the method of enabling this bridge as done in the above link.
I am still not sure how we can achieve this after preloader application starts in sdram,.
ran
