15 years ago
EMP1270 BGA burning up
On a new design we have a repeated problem that the EMP1270 developes a short between pwr and gnd and smokes. Single 3.3v supply operation, all other devices on board on same supply. The only exposed CPLD pins are Jtag and some GPIO's for debug, we have anti static ESD foam across all pins on the headers.
The problem only happens on power up, once board is up, no problems.
We suspect either ESD or some random overshoot of the 3.3V, using a switcher regulator, LM2678. watching a scope, didn't see any overshoot for dozens of power up cycles.
Any other theories are welcome. this has happened on different board designs, boards assembled by different places.
Can/will Altera perform an analysis on blown part?
Does the symptoms, pwr gnd short, point to one theory or the other?
I assume the CPLD would be most sensitive to supply overshoot due to it's 2.5V capability, indicating thinner gate oxide than a pure 3.3V part?
ideas and thoughts welcome
    Is it just the CPLD that blows up? How about the other components? Is the switching regulator still up and running properly?
    have you seen this post?
    configuration cycloniv with 2.5v and epcs with 3.3v
    (20th sept)
    Sometimes with switchers we get 'magic finger' problems
    -- which means your scope probe will 'fix' it while connected, hence hard to spot
    I'm not saying that's what you have, but if you have a suitable bench supply, might suggest using that for a while to remove switcher from equation -- at least you've removed one unknown!
