15 years agoEMP1270 BGA burning up
On a new design we have a repeated problem that the EMP1270 developes a short between pwr and gnd and smokes. Single 3.3v supply operation, all other devices on board on same supply. The only exposed...
15 years agoSometimes with switchers we get 'magic finger' problems
-- which means your scope probe will 'fix' it while connected, hence hard to spot I'm not saying that's what you have, but if you have a suitable bench supply, might suggest using that for a while to remove switcher from equation -- at least you've removed one unknown!
