8 years agoEffect of nCE (Chip Enable)
Does nCE=High only disable the Configuration pins or would other pins also be affected? And does "disable" imply that the affected pins are high impedance? What happens if nCE is driven high in...
8 years agoHello FvM,
The intended application is FPP via a Host, not AS via memory - see previous post, please.
