8 years agoEffect of nCE (Chip Enable)
Does nCE=High only disable the Configuration pins or would other pins also be affected? And does "disable" imply that the affected pins are high impedance? What happens if nCE is driven high in...
8 years agoHello Anand,
Thank you for the reply. Could you elaborate on the effect of nCE=High in User Mode, please? Which pins can nCE affect? Why is it recommended that nCE be held low during User Mode, for example also in the link you provide?
