8 years agoEffect of nCE (Chip Enable)
Does nCE=High only disable the Configuration pins or would other pins also be affected? And does "disable" imply that the affected pins are high impedance? What happens if nCE is driven high in...
8 years agoHi,
--- Quote Start --- Does nCE=High only disable the Configuration pins or would other pins also be affected? --- Quote End --- No, FPGA will remain configured and works fine if nCE high during user mode. --- Quote Start --- What happens if nCE is driven high in User Mode after Configuration? Would the part continue to operate internally and on any unaffected pins? --- Quote End --- Intel FPGA will not lose its configuration contents if the nCE pin is pulled high during user mode https://www.altera.com/support/support-resources/knowledge-base/solutions/rd01102011_672.html Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
