17 years agoed8b10b encoder/decoder
Hello! I have a problem whit the ed8b10b encoder/decoder. I recently bought a quartus II license from altera and i also own a stratix II FPGA board. The quartus II software includes the ed8b1...
17 years agoDear FvM!
can i have an email address so i can let you know better about my steps? I tryed the STX cookbook and still not working, i get the same errors: Info: Successfully loaded and ran Tcl Script File "C:\Documents and Settings\Vaio\Bureau\ed8b10b\test_constraints.tcl" Info: Started Full Compilation at Thu Dec 04 00:15:43 2008 Paris, Madrid Info: Ended Full Compilation at Thu Dec 04 00:17:06 2008 Paris, Madrid Info: SRAM Object File C:/Documents and Settings/Vaio/Bureau/ed8b10b/test_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0x0079 Info: Started Programmer operation at Thu Dec 04 00:17:30 2008 Info: Configuring device index 1 Info: Device 1 contains JTAG ID code 0x120930DD Info: Configuration succeeded -- 1 device(s) configured Info: Successfully performed operation(s) Info: Ended Programmer operation at Thu Dec 04 00:17:36 2008 Error: Can't communicate with device. Device will stop functioning when it reaches its non-tethered mode timeout limit. Thank you very much for youre question.
