Oliver_I_Sedlacek
Contributor
2 years agoEclipse can't find sopcinfo file but it's there!
The my_nios.sopcinfo is exactly where it should be and where Eclipse says it's looking, but a build gives this: I've tried a clean, all the index refresh options, restart, all to no avail,
wwanalim_intel
Contributor
2 years agoHi Oliver,
Sorry that you still facing the error. So far, most of the issue did not generate the sopcinfo.
Since, the Eclipse IDE cannot find the .sopcinfo file, hope you can try to open the IDE with administration mode and also try to shorten the file location path. As I checking previous thread, there is someone before also posted that it could be the file location path is too long.
- Oliver_I_Sedlacek2 years ago
Contributor
I'm a bit stumped by both those suggestions. The path is exactly the same as on my old PC where it all worked, and previous experience tells me you can't just move an Eclipse project, you will break it.
I only ever start Eclipse from the Quartus tools menu, so how do I start it in administrator mode?
