Oliver_I_Sedlacek
Contributor
2 years agoEclipse can't find sopcinfo file but it's there!
The my_nios.sopcinfo is exactly where it should be and where Eclipse says it's looking, but a build gives this: I've tried a clean, all the index refresh options, restart, all to no avail,
wwanalim_intel
Contributor
2 years agoHi Oliver,
Can you provide screenshot after you generate the bsp, would like to see the "finished generating files.
Right now it seems that bsp is success but the build run into problem as did not found the sopcinfo file.
Did you try to run the nios2 program?
Thank you.
Fathulnaim.
Oliver_I_Sedlacek
Contributor
2 years agoCan't run the NIOS2 program because I can't build it.
BSP generation screenshot below.
