Oliver_I_Sedlacek
Contributor
2 years agoEclipse can't find sopcinfo file but it's there!
The my_nios.sopcinfo is exactly where it should be and where Eclipse says it's looking, but a build gives this: I've tried a clean, all the index refresh options, restart, all to no avail,
wwanalim_intel
Contributor
2 years agoHi Oliver,
You can import the project into your eclipse to solve this issue and ensure the directory is correct.
Below are steps to import the eclipse project -
- Right click on the project explorer area.
- Click Import --> Nios II Software Build Tools Project --> Import Nios II Software Build Tools Project
- Click Browse and direct it to the project file of your Nios2 project. Ensure name of project matches folder.
- Repeat the step for import BSP files. Ensure name of BSP matched folder.
- After that, can open the BSP editor to check the sopc file point to the correct directory.
Thank you.
- Oliver_I_Sedlacek2 years ago
Contributor
That's exactly how I imported the project. When I open the BSP editor the Information window includes the message that it finished loading my_nios.sopcinfo so the BSP editor is happy.
