E144-Pin package exposed ground pad issue
- 7 years ago
Absolutely you want to connect the ground pad directly to the ground plane. Don't use long traces to wire it to the other ground pins. They should connect direct to the ground plane as well with a local via per pin. Ditto for VCC pins that connect to a VCC plane (if present).
As to whether you can have VIAs directly within the EPAD it depends on the capability of your PCB vendor and assembly house. Some allow VIA-in-PAD, others may not want you to do that, and instead have the VIAs just outside the EPAD connected by short traces.
