13 years agoDynamic Partial Reconfiguration & Direct Bitstream File Manipulation
Hi people, Three questions: What are the Altera FPGAs and their respective development kits that work with DPR (Dynamic Partial Reconfiguration)? Is there any Altera software prod...
13 years agoThank you Alex,
I will check Cyclone and Stratix for DPR. and Yes, I am reffering to the bitstream configuration file. In this case is the .sof file. The reasons for that rely on a research area called Evolvable Hardware. In a few words, we need to run the following loop: 1-.sof file generation; 2-download the bitstream file configuration to the development board; 3-circuit/system evalutation; 4-if termination condition reached go to step 1; 5-final circuit/system generated. This loop needs to be executed in a "population" of circuit-candidates for each circuit, dozens of times, i.e., population# 1,# 2, ..., until final population. In this scenario, the time spent is intractable if we need to synthesize, place and route and generate each .sof file (each circuit-candidate) for just one population. Xilinx JBits, for example is a tool that allows direct bitstream manipulation, but there are some problems regarding opening documentation, other restriction problems regarding the type of FPGA device to be bitstream-file-edited, and the tool itself I suspect it is discontinued. So, if I find an Altera or other vendor specific tool that allows me the processing of step "1" directly, it will accelerate my executions tremendously. Regards Jaraqui
