15 years agoDual Port Ram problems : Synthesizes error with one or two clock signals
Hello, I was running in a problem and can't find a way out . Although there are already a lot of posts concerning problems with dual port rams, I couldn't found a solution. I am using a DE1 boa...
15 years agoFvM already found for you the trick (also given personal advice on reading errors - thanks to Frank).
add this statement: set_parameter -name CYCLONEII_SAFE_WRITE VERIFIED_SAFE to your qsf then it will support two clocks dual port ram
