9 years agoDual-port access avalon memory simulation problem
Hello, I have created an Avalon dual access on-chip memory in Qsys and tried to simulate it, with success, everything worked just fine. Then I put this module in a VHDL component, and did nothi...
9 years agoThe code for my testbench is:
LIBRARY altera_mf ; LIBRARY ieee ; LIBRARY std ; USE altera_mf.all ; USE ieee.std_logic_1164.all ; USE ieee.std_logic_textio.all ; USE ieee.std_logic_unsigned.all ; use ieee.numeric_std.all; USE std.textio.all ; ENTITY tau2_temp_calculate_tb IS END ; ARCHITECTURE tau2_temp_calculate_tb_arch OF tau2_temp_calculate_tb IS SIGNAL onchip_memory2_0_clk1_clk : STD_LOGIC; SIGNAL onchip_memory2_0_s1_address : STD_LOGIC_VECTOR(13 DOWNTO 0); SIGNAL onchip_memory2_0_s1_readdata : STD_LOGIC_VECTOR(31 DOWNTO 0); SIGNAL onchip_memory2_0_clk2_clk : std_logic; SIGNAL onchip_memory2_0_reset2_reset : std_logic; SIGNAL onchip_memory2_0_s2_address : std_logic_vector(13 downto 0); SIGNAL onchip_memory2_0_s2_chipselect : std_logic; SIGNAL onchip_memory2_0_s2_clken : std_logic; SIGNAL onchip_memory2_0_s2_write : std_logic; SIGNAL onchip_memory2_0_s2_readdata : std_logic_vector(31 downto 0); SIGNAL onchip_memory2_0_s2_writedata : std_logic_vector(31 downto 0); SIGNAL onchip_memory2_0_s2_byteenable : std_logic_vector(3 downto 0); SIGNAL onchip_memory2_0_reset1_reset : std_logic; SIGNAL onchip_memory2_0_s1_clken : std_logic; SIGNAL onchip_memory2_0_s1_chipselect : std_logic; SIGNAL onchip_memory2_0_s1_write : std_logic; SIGNAL onchip_memory2_0_s1_writedata : std_logic_vector(31 downto 0); SIGNAL onchip_memory2_0_s1_byteenable : std_logic_vector(3 downto 0); COMPONENT tau2_temp_calculate PORT( onchip_memory2_0_clk1_clk : IN STD_LOGIC; onchip_memory2_0_s1_address : IN STD_LOGIC_VECTOR(13 DOWNTO 0); onchip_memory2_0_s1_readdata : OUT STD_LOGIC_VECTOR(31 DOWNTO 0); onchip_memory2_0_clk2_clk : in std_logic; onchip_memory2_0_reset2_reset : in std_logic; -- onchip_memory2_0_reset2.reset onchip_memory2_0_s2_address : in std_logic_vector(13 downto 0); -- onchip_memory2_0_s2.address onchip_memory2_0_s2_chipselect : in std_logic; -- .chipselect onchip_memory2_0_s2_clken : in std_logic; -- .clken onchip_memory2_0_s2_write : in std_logic; -- .write onchip_memory2_0_s2_readdata : out std_logic_vector(31 downto 0); -- .readdata onchip_memory2_0_s2_writedata : in std_logic_vector(31 downto 0); -- .writedata onchip_memory2_0_s2_byteenable : in std_logic_vector(3 downto 0); onchip_memory2_0_reset1_reset : in std_logic; onchip_memory2_0_s1_clken : in std_logic; onchip_memory2_0_s1_chipselect : in std_logic; onchip_memory2_0_s1_write : in std_logic; onchip_memory2_0_s1_writedata : in std_logic_vector(31 downto 0); onchip_memory2_0_s1_byteenable : in std_logic_vector(3 downto 0) ); END COMPONENT; BEGIN tau2_temp_calculate_inst: tau2_temp_calculate PORT MAP( onchip_memory2_0_clk1_clk =>onchip_memory2_0_clk1_clk, onchip_memory2_0_s1_address =>onchip_memory2_0_s1_address, onchip_memory2_0_clk2_clk =>'0', onchip_memory2_0_reset2_reset=>'0', onchip_memory2_0_s2_address=>(others => '0'), onchip_memory2_0_s2_chipselect=>'0', onchip_memory2_0_s2_clken=>'0', onchip_memory2_0_s2_write=>'0', onchip_memory2_0_s2_readdata=>onchip_memory2_0_s2_readdata, onchip_memory2_0_s2_writedata=>(others => '0'), onchip_memory2_0_s2_byteenable=>(others => '0'), onchip_memory2_0_reset1_reset=>'0', onchip_memory2_0_s1_clken => '1', onchip_memory2_0_s1_chipselect=> '1', onchip_memory2_0_s1_write => '0', onchip_memory2_0_s1_writedata => "00000000000000000000000000000000", onchip_memory2_0_s1_byteenable=> (others => '1') ); Process variable DataIN : unsigned(13 downto 0); Begin DataIN:=to_unsigned(0,DataIN'length); for Z in 1 to 16383 loop onchip_memory2_0_s1_address <= std_logic_vector(DataIN) ; wait for 47532 ps; DataIN:=DataIN+to_unsigned(1,DataIN'length); end loop; wait; End Process; Process Begin for Z in 1 to 16383 loop onchip_memory2_0_clk1_clk <= '1' ; wait for 23766 ps ; --"1" period:1/2*(10^12/147.27*10^6) onchip_memory2_0_clk1_clk <= '0' ; wait for 23766 ps ; --"0" period:1/2*(10^12/147.27*10^6) end loop; wait; End Process; END;
