9 years agoDual-port access avalon memory simulation problem
Hello, I have created an Avalon dual access on-chip memory in Qsys and tried to simulate it, with success, everything worked just fine. Then I put this module in a VHDL component, and did nothi...
9 years agoHello,
Thank you for your reply, you can find the code to instantiate the component below. I do not think I left anything unconnected, as you can see on the picture attached(I unchecked the reset request option on generation). LIBRARY ieee; USE ieee.std_logic_1164.all; LIBRARY work; ENTITY tau2_temp_calculate IS PORT( onchip_memory2_0_clk1_clk : IN STD_LOGIC; onchip_memory2_0_s1_address : IN STD_LOGIC_VECTOR(13 DOWNTO 0); onchip_memory2_0_s1_readdata : OUT STD_LOGIC_VECTOR(31 DOWNTO 0); onchip_memory2_0_clk2_clk : in std_logic; onchip_memory2_0_reset2_reset : in std_logic; -- onchip_memory2_0_reset2.reset onchip_memory2_0_s2_address : in std_logic_vector(13 downto 0); -- onchip_memory2_0_s2.address onchip_memory2_0_s2_chipselect : in std_logic; -- .chipselect onchip_memory2_0_s2_clken : in std_logic; -- .clken onchip_memory2_0_s2_write : in std_logic; -- .write onchip_memory2_0_s2_readdata : out std_logic_vector(31 downto 0); -- .readdata onchip_memory2_0_s2_writedata : in std_logic_vector(31 downto 0); -- .writedata onchip_memory2_0_s2_byteenable : in std_logic_vector(3 downto 0); onchip_memory2_0_reset1_reset : in std_logic; onchip_memory2_0_s1_clken : in std_logic; onchip_memory2_0_s1_chipselect : in std_logic; onchip_memory2_0_s1_write : in std_logic; onchip_memory2_0_s1_writedata : in std_logic_vector(31 downto 0); onchip_memory2_0_s1_byteenable : in std_logic_vector(3 downto 0) ); END tau2_temp_calculate; ARCHITECTURE bdf_type OF tau2_temp_calculate IS COMPONENT temp_table port ( onchip_memory2_0_clk1_clk : in std_logic; onchip_memory2_0_clk2_clk : in std_logic; onchip_memory2_0_reset1_reset : in std_logic; onchip_memory2_0_reset2_reset : in std_logic; onchip_memory2_0_s1_address : in std_logic_vector(13 downto 0); onchip_memory2_0_s1_clken : in std_logic; onchip_memory2_0_s1_chipselect : in std_logic; onchip_memory2_0_s1_write : in std_logic; onchip_memory2_0_s1_readdata : out std_logic_vector(31 downto 0); onchip_memory2_0_s1_writedata : in std_logic_vector(31 downto 0); onchip_memory2_0_s1_byteenable : in std_logic_vector(3 downto 0); onchip_memory2_0_s2_address : in std_logic_vector(13 downto 0); onchip_memory2_0_s2_chipselect : in std_logic; onchip_memory2_0_s2_clken : in std_logic; onchip_memory2_0_s2_write : in std_logic; onchip_memory2_0_s2_readdata : out std_logic_vector(31 downto 0); onchip_memory2_0_s2_writedata : in std_logic_vector(31 downto 0); onchip_memory2_0_s2_byteenable : in std_logic_vector(3 downto 0) ); END COMPONENT; begin temp_table_inst: temp_table PORT MAP( onchip_memory2_0_s1_readdata=> onchip_memory2_0_s1_readdata, onchip_memory2_0_s1_address => onchip_memory2_0_s1_address, onchip_memory2_0_clk1_clk=>onchip_memory2_0_clk1_clk, onchip_memory2_0_reset1_reset=>onchip_memory2_0_reset1_reset, onchip_memory2_0_s1_clken => onchip_memory2_0_s1_clken, onchip_memory2_0_s1_chipselect=> onchip_memory2_0_s1_chipselect, onchip_memory2_0_s1_write => onchip_memory2_0_s1_write, onchip_memory2_0_s1_writedata=> onchip_memory2_0_s1_writedata, onchip_memory2_0_s1_byteenable=> onchip_memory2_0_s1_byteenable, onchip_memory2_0_clk2_clk =>onchip_memory2_0_clk2_clk, onchip_memory2_0_reset2_reset => onchip_memory2_0_reset2_reset, onchip_memory2_0_s2_address => onchip_memory2_0_s2_address, onchip_memory2_0_s2_chipselect => onchip_memory2_0_s2_chipselect, onchip_memory2_0_s2_clken => onchip_memory2_0_s2_clken, onchip_memory2_0_s2_write => onchip_memory2_0_s2_write, onchip_memory2_0_s2_readdata =>onchip_memory2_0_s2_readdata, onchip_memory2_0_s2_writedata => onchip_memory2_0_s2_writedata, onchip_memory2_0_s2_byteenable => onchip_memory2_0_s2_byteenable ); END bdf_type;
