8 years agoDual Boot from QSPI Flash Memory
I'm using the Cyclone V Gx Starter Kit from terasic and I'm trying to dual boot from the QSPI Flash memory (2 FPGA images and 2 Nios II images). I'm using Quartus 17.1. First, I have followed the procedure mentioned on this link "https://www.altera.com/documentation/iga1446487888057.html#exd1481216473856" section "Nios II Processor Application Copied from QSPI Flash to RAM Using RAM Using Boot Copier". I'm using the "Altera Generic QUAD SPI controller II" with a clk at 20MHz and I have set a reset vector offset to address 0x003C0000. I have generated this .pof :- Sof Data / Start Address
- Factory FPGA image / 0x00000000
- Hex Data / Start Address
- Factory Nios II image / 0x003C0000
- Factory Nios II image / 0x003c0000
- Application FPGA image / 0x00400000
- Application Nios II image / 0x007C0000
- For the Application FPGA image should I set the reset vector offset to address 0x007C0000 ?
- In this link "https://www.altera.com/documentation/lro1432739743862.html#lro1432740750432" section "Nios II Processor Booting Methods" I find that the boot copier supported for an EPCQ is the Memcpy-based. Is the Memcpy-based refer to the boot_loader_cfi_bits ?
- When I generate the "mem_init.mk" script it uses the following program "alt-file-convert -I elf32-littlenios2 -O hex --input=terasic_epcq.elf --output=mem_init/generic_quad_spi_controller2.hex --base=0x02000000 --end=0x03ffffff --reset=0x023c0000 --out-data-width=8 --boot="C:/altera/17.1/nios2eds/components/altera_nios2/boot_loader_cfi.srec" to generate the Nios II image with the following boot loader : "boot_loader_cfi_bits". Is it not weird to use the boot loader "Common Flash Interface" for a EPCQ flash memory ?
- Is it possible to use another boot loader with the "Altera Generic QUAD SPI controller II" ? (the boot_loader_universal_bits for example)
1 Reply
Resolved;.
