14 years ago
DSP code snippets
I thought the following link to code snippets at dsprelated.com may further help members of this forum.
http://www.dsprelated.com/showcode/241.php
My contributions thus far include:
16QAM Modem (basic model)
NCO phase drift
NCO phase continuity
NCO bit true model
IQ conjugates
complex filter using 3 multipliers
even/odd FIR structure
vector alignment
OFDM symbol model
kaz (kadhiem ayob)
    The two inputs (.25 & 1) to function firrcos represent as you know sampling frequency of filter module and its cutoff.
    The term Fs and Fc I use them for different purpose in the main program.
    Fs is the final digital IF. Fc is centre frequency for upconversion. So both are unrelated to filter stage.
    For firrcos, the minimum practical upsampling is x2 hence we need to cut off at Nyquist relative to Fs of 2 i.e you can enter as .5 & 2 or .25 & 1. The actual physical sampling frequency of filter is normalised here to 1.
    The code implies symbol rate = 12.5 Msps and so upcomverted to 25 by filter then to 100 by upsampling stage then frequency shifted to 10MHz.
    I edited that snippet accordingly to make this point clearer, thanks for the question.
    kaz
    HI kaz
    In the pulse shaping, root raised cosine
    h = firrcos(50,.25,.15,1,'rolloff','sqrt');
    Can u explain me why 0.25 and 1 are taken in the RRC function which represent cutoff and sampling
    as
    Fs = 100; %MHz, IF sampling frequency
    Fc = 20; %MHz, upconverter frequency
    Fc/Fs = 20/100 = 0.2
    so can i use
    h = firrcos(50,.2,.15,1,'rolloff','sqrt');
