10 years agoDSP Builder doesn't compile the Simulink files
Hello, thank you for see this post.
DSP Builder doesn't compile the Simulink files. I'm using MATLAB R2013 Student Version. I want to transform my original Simulink file into VHDL file by SignalCompiler(DSP Builder) in order to implement to CycloneⅢ EP3C 120 FPGA Development Board by Quartus Ⅱ 12.1sp1 Web Edition(32bit). But when I open the window of Signal Compiler and push the button to compile the file, this message appears↓ Info: Generating HDL Info: Analyzing Simulink model Matlab Error テGテノチ[ alt_dspbuilder_mdl2xml (line 36) Java exception occurred: com.altera.dspbuilder.common.DSPBuilderException: Unable to obtain a DSP Builder license. Please check that your LM_LICENSE_FILE environment variable is set to a valid license file or license server. LM_LICENSE_FILE is currently "[email protected]". at com.altera.dspbuilder.serialisation.ModelSerialiser.<init>(Unknown Source) at com.altera.dspbuilder.serialisation.ModelSerialiser.<init>(Unknown Source) at com.altera.dspbuilder.serialisation.ModelSerialiser.<init>(Unknown Source) Error: Error during compilation: Error: Error analyzing model see log for details. This message also appears when I compile the existing test program. For example,"in_out.mdl". What is wrong???No RepliesBe the first to reply
