11 years agoDS-5 launching the debugger from the command-line console
Hallo, every one: I have a big Problem to ask here and i need your help: We use the Altera Cyclone V SOC(Cortex A9) Chip in our project. Wenn we work under DS-5. with Debug directly i...
11 years ago --- Quote Start --- Hi, Yong: The Chipset we use Altera Cyclone V and Hardware Debugger is Altera USB-Blaster actually we wanne under DS-5 with USB-Blaster to create a .rvc File, but ARM Support says that not worked, one must with DSTREAM. So do u konw onthers Software with that we wanne only our Software Code in Hardware Memory to flashen. Regards Wenguo Hu --- Quote End --- Hi Wenguo, Sorry I just saw your post because all the Altera Forum email being treated as spam. I hope I am still helpful to you. If I am not mistaken, you want to work with your USB-Blaster under DS-5 but ARM support claim that you must use DSTREAM. I managed to work with USB Blaster and USB Blaster II too. Please let me know if you want to use your USB Blaster hardware and uses DS-5 to flash/debug the chip. It is do able. Regards Yong
