11 years agoDS-5 launching the debugger from the command-line console
Hallo, every one: I have a big Problem to ask here and i need your help: We use the Altera Cyclone V SOC(Cortex A9) Chip in our project. Wenn we work under DS-5. with Debug directly i...
11 years ago --- Quote Start --- Hi wenguo, May I know what is the hardware you used? I have a complete working headless command set and I think I can help you on this. First you must tell me what hardware (Chipset and Hardware debugger - USB Blaster or DStream). Regards Yong --- Quote End --- Hi, Yong: The Chipset we use Altera Cyclone V and Hardware Debugger is Altera USB-Blaster actually we wanne under DS-5 with USB-Blaster to create a .rvc File, but ARM Support says that not worked, one must with DSTREAM. So do u konw onthers Software with that we wanne only our Software Code in Hardware Memory to flashen. Regards Wenguo Hu
