Drop in replacement for M25P32, will the AT25SF321B work?
- 5 years ago
Hi Stu,
Thanks for your clarification. Micron and Macronix are the 3rd party flash that we are supporting only as we have tested and proven working fine with our FPGA.
You may use other flash as well but you need to do your own assessment and use it with your own risk. If it is working fine previously, I don't see any point of not working.
Thanks You.
Bruce
Hi Stu,
Thanks You.
Bruce
- SSmit75 years ago
Hi there
Thanks for the input.
I have accepted the previous answer as the solution.
