14 years agoDriving LEDs from 1.8V outputs
I need to drive some LEDs from the 1.8V outputs on my Arria II GX device. The plan is to simply connect the LEDS to 3.3V (through a resistor) and make the ouptut open drain. Will this be OK? It will of course cause the ouptut to be pulled up to 3.3V when the LED is off. The datasheet suggests that the output can stand up to 3.6V. Thanks -Tim2 Replies
The output can stand up to 3.6V but why risk it. Can’t you reverse the polarity of the LEDs and give a ground signal from the controller. That way the LEDs will work at 1.8V when you give them a ground signal.
That will be fine.
