14 years agoDriving LEDs from 1.8V outputs
Hello, I need to drive some LEDs from the 1.8V outputs on my Arria II GX device. The plan is to simply connect the LEDS to 3.3V (through a resistor) and make the ouptut open drain. Will this ...
13 years agoThe output can stand up to 3.6V but why risk it. Can’t you reverse the polarity of the LEDs and give a ground signal from the controller. That way the LEDs will work at 1.8V when you give them a ground signal.
