14 years agoDriving a module output with a reg?
Hello, I'm trying to determine the best way to gain access to the output of a module which is simply a wire - who in it's own module is driven by a continuous assignment statement. The p...
14 years ago@BadOmen: Thanks for the reply.
Why is this typically a style that you avoid? I'm trying to learn best practices still. Also, why would the integer not be able to reach 0 - should I use registers for this value instead? Thanks, Kristin
