16 years agoDrive strength settings
Hello: Just starting with FPGA design When the FPGA (cyclone II) drives pins into a device with a specific loading value (i.e 10pf) , is there a calculation or rule thumb to estimate wha...
16 years ago --- Quote Start --- You can extract the exact output characteristic for each current strength setting from the IBIS files and calculate the respective dynamical response or use a tool, that does the calculation. --- Quote End --- Would you mind elaborating in what tools and a little more details on how you do this exactly? thanks again
