16 years agoDrive strength settings
Hello: Just starting with FPGA design When the FPGA (cyclone II) drives pins into a device with a specific loading value (i.e 10pf) , is there a calculation or rule thumb to estimate wha...
16 years agoThere can't be a rule of thumb because the best setting also depends on signal speed and required rise time respectively acceptable signal delays. I usually choose minimum current for general purpose I/O, higher values possibly for clock lines or fast memory interfaces.
--- Quote Start --- sometimes not all signals are available to connect a scope --- Quote End --- I think, it's sufficient to connect one signal to an oscilloscope to see the basic effects of current strength settings.
