Oliver_I_Sedlacek
Contributor
3 years agoDPRAM synthesised by IP Parameter Editor Pro wont compile
Moving from Quartus 20.1 Lite to Quartus 23.1 Pro I used the IP editor to generate a fresh DPRAM design, simple enough 128 words of 32 bits with separate read and write ports. Target is Cyclone 10 GX...
- 3 years ago
So the problem was no clk62pci, which was a bit harder to fix than anticipated. A PLL was the obvious source for the development stage, but it took a while to get two IOPLLs running off the same 50 MHz input on the Cyclone 10 GX evaluation board.
Thanks for asking the right question.
sstrell
3 years agoCan you show the rest of the upper level code around this instantiation? Where are clk62pci and clk100sys coming from?
Oliver_I_Sedlacek
Contributor
3 years agoSo the problem was no clk62pci, which was a bit harder to fix than anticipated. A PLL was the obvious source for the development stage, but it took a while to get two IOPLLs running off the same 50 MHz input on the Cyclone 10 GX evaluation board.
