DPRAM synthesised by IP Parameter Editor Pro wont compile
- 3 years ago
So the problem was no clk62pci, which was a bit harder to fix than anticipated. A PLL was the obvious source for the development stage, but it took a while to get two IOPLLs running off the same 50 MHz input on the Cyclone 10 GX evaluation board.
Thanks for asking the right question.
Can you show the rest of the upper level code around this instantiation? Where are clk62pci and clk100sys coming from?
- Oliver_I_Sedlacek3 years ago
Contributor
Contributor
This block is buried deep, but I think you've asked the key question. clk100sys comes from a PLL, no issues, but clk62pci comes from the PCIe endpoint wrapper, which is currently commented out! I'll set up a source for clk62pci and report back.
