14 years agoDownload vhdl code into fpga board Problem
Hi all, I get stuck here. I try to download a vhdl code into fpga board using Tools>Programmer. After I click the Programmer, I get the warning box as attached. Then, the .sof file created is s...
14 years agoThis happens because your design includes an IP core used in OpenCore evaluation mode, namely without buying a license.
The core will fully work until you keep the programmer attached, whereas it will stop functioning if you press the Ok button and close that message box.
