Don't work ALTDDIO_OUT for Cyclone5
Hello, dear friends
I use 5CGXFC5C6F23I7
I am using IP ALTDDIO_OUT in my project with triple speed ethernet to generate ETH_GTX_CLK
I carry it out as follows:
wire eth1_pll_clk_2p5;
wire eth1_pll_clk_25;
wire eth1_pll_clk_125;
pll eth1_pll_inst (
.rst ( !any_rst_n )
,.refclk ( CLOCK_25_FPGA )
,.outclk_0 ( eth1_pll_clk_2p5 )
,.outclk_1 ( eth1_pll_clk_25 )
,.outclk_2 ( eth1_pll_clk_125 )
,.outclk_3 ( )
,.outclk_4 ( )
wire eth1_mdio_oen;
wire eth1_mdio_out;
wire eth1_mode;
wire eth1_ena_10;
reg eth1_tx_clk;
eth_altddio_out eth1_altddio_out_inst (
.aclr ( !any_rst_n ),
.datain_h ( 1'b1 ),
.datain_l ( 1'b0 ),
.outclock ( eth1_tx_clk ),
.dataout ( ETH1_GTX_CLK )
always @(*)
begin
if (any_rst_n == 1'b0) eth1_tx_clk <= 1'b0;
else if (eth1_mode) eth1_tx_clk <= eth1_pll_clk_125;// GbE Mode = 125MHz clock
else if(eth1_ena_10) eth1_tx_clk <= eth1_pll_clk_2p5;// 10Mb Mode = 2.5MHz clock
else eth1_tx_clk <= eth1_pll_clk_25; // 100Mb Mode = 25MHz clock
endcode altddio_out:
module eth_altddio_out (
aclr,
datain_h,
datain_l,
outclock,
dataout);
input aclr;
input [0:0] datain_h;
input [0:0] datain_l;
input outclock;
output [0:0] dataout;
wire [0:0] sub_wire0;
wire [0:0] dataout = sub_wire0[0:0];
altddio_out ALTDDIO_OUT_component (
.aclr (aclr),
.datain_h (datain_h),
.datain_l (datain_l),
.outclock (outclock),
.dataout (sub_wire0),
.aset (1'b0),
.oe (1'b1),
.oe_out (),
.outclocken (1'b1),
.sclr (1'b0),
.sset (1'b0));
defparam
ALTDDIO_OUT_component.extend_oe_disable = "OFF",
ALTDDIO_OUT_component.intended_device_family = "Cyclone V",
ALTDDIO_OUT_component.invert_output = "OFF",
ALTDDIO_OUT_component.lpm_hint = "UNUSED",
ALTDDIO_OUT_component.lpm_type = "altddio_out",
ALTDDIO_OUT_component.oe_reg = "UNREGISTERED",
ALTDDIO_OUT_component.power_up_high = "OFF",
ALTDDIO_OUT_component.width = 1;
endmoduleafter synthesis, I see at RTL level that this block is present in the project, all the inputs and outputs are set up by Quartus, but at the same time, when I look at real hardware through signaltab, I do not see this output, or rather it hangs at a constant 0, also I do not see oscilloscope generation from a given cortex
at the same time, the eth1_tx_clk signal switches and issues a clock as it should, if you start it directly:
assign ETH1_GTX_CLK = eth1_tx_clk;
then the shred appears on ETH1_GTX_CLK, but if it is output via ALTDDIO_OUT, then it is not
what could be the problem?
1 Reply
- xxxmatrixxx
I saw article
https://forums.intel.com/s/question/0D50P00003yyTLpSAM/altddioout-for-clock-output-of-chip
how i can saw picture on signaltap from altddio_out on CYCLONE5?
