13 years agoDoes TI's Power desgin reference suites for Altera's FPGA?
TI's Reference:http://www.ti.com/analog/docs/refdesignovw.tsp?familyid=64&contenttype=2&gencontentid=148209 what about the design correct? why Altera does not supply the similar reference?...
13 years ago --- Quote Start --- what about the design correct? --- Quote End --- Nothing is correct until you simulate and verify it. Texas Instruments has a SPICE-like tool called TI-TINA. Its developed by another company. I've looked at the free version, but have been underwhelmed by its features. I've used Linear Technology's LTspice tool for simulation of their switch-mode power supplies, and it does a decent job. Texas Instruments does have low-cost development boards for their power supplies. I'd recommend buying and testing them if you want to use their parts. --- Quote Start --- why Altera does not supply the similar reference? --- Quote End --- Because there is no one reference design that meets all users needs. Altera provides the pin-connections guidelines files which have their recommendations for power. You need to create your own power requirements document, and then draw up a block diagram of the power supplies, and then simulate. Here's an example http://www.ovro.caltech.edu/~dwh/wbsddc/ts4_power.pdf This design is still a work-in-progress, as for example, simulation and hardware tests of some of the parts shows they have issues. Cheers, Dave
