13 years agoDoes Quartus II Programmer checks the device ID before EPCS programming ?
I'd like to put on my board a 1-Gbit serial Flash as programming device instead of the classical EPCS128 or EPCQ256 devices (I need to store several user "big" applications in an ArriaV-B7 for Remote System Update).
Has someone already experienced the AS programming scheme with non-Altera Flash ? Indeed, I'm wondering if the Quartus II programmer check any Device ID to eventually block a non-EPCS/EPCQ device programming. And what about programming via JTAG (.jic file via SFL) ? Thanks !1 Reply
yes it does check the ID. have a look in the Advanced section of the Convert Programming Files menu. there is a Disable EPCS ID Check selection you'll need to enable
i'm unsure how using the 1Gb flash will go
