Does de-assertion of DEV_OE affect acces to JTAG port functions?
- 5 years ago
DEV_OE doesnt affect the configuration. Enable "Enable Chip-Wide Output Enable" will change the functionality of this input pin to override all tri-states on the device. When this pin is driven low, all I/O pins are tri-stated. When this pin is driven high, all I/O pins behave as programmed.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/PCG-01018.pdf (Page 6)
Thank You
Thank You
