14 years agoDo MaxII devices verify flash contents before configuring at power on?
In FMEA analysis of a board using a MaxII CPLD the question came up, do the MaxII devices perform some kind of CRC or checksum check on the configuration flash (CFM) contents before configuration? In...
14 years ago --- Quote Start --- You could answer ALTERA via a service request (I'm interested in the response too ;-) ). From my experience (our materials are under 14 MeV neutrons and high energies gamma beams), it seems that when the CFM is corrupted, the MAX should be reprogrammed to recover. --- Quote End --- If the configuration consistency is checked, I would expect MAX II staying in unconfigured state (all pins tri-stated with weak pull-up), otherwise it might show arbitrary erroneous behaviour. Did you remember the behaviour in this single evident? I agree, that only Altera can answer the question fully.
